wont finish wash stops error code F35 + CHEK SUDS not using too much suds,after unpluging and restarting several times it will finish cycle some times.also blew through water pressure hose its clear,looked at steam board no abnormalities but dont know how to chek.can anyone give me a heads up?THANKS IN ADVANCE!
— Begin quote from wapiwulo;441037
Wapiwulo,
Did you check or replace the analog pressure switch ?
[part]AP4323930[/part]
Since the air dome hose is clear and you’re sure there’s no residual suds in the drum, this would be the next step in diagnosing the F35 code and the Suds detect circuit.
Good Luck,
