I am trying to figure out an issue with my Whirlpool Duet washer, model GHW9200LW. The unit stopped working/responding to the controls two days ago. I began trouble shooting by removing the top panel and checking for loose/damaged wires. I did not spot any. I unplugged all wire connections from the back of the CCU, plugged the washer back in and it worked until I pressed the ‘pause/cancel’ button. After pressing the button it stopped working. I tried unplugged wires again but this time it would not turn on at all. After doing some research on this site and other sites I figured I would replace the Command Control Unit-CCU (part#8181924). Today I picked up a new CCU and swapped out the old for the new. After plugging the washer back in it started up again. The new CCU came with a note to press the ‘pause/cancel’ button twice to clear the memory after plugging it in. I did this and now I can’t get the unit to turn on again. What is going on with this washer? Is there a reset button or sequence of buttons that can be pressed to get the unit to turn on again? Or does the CCU need to be replaced again? I have measured the voltage at the power supply and at the board and I get 120volts. I also checked the display board connection and I receive 5.95 Vdc.
Any help would be much appreciated.
