Folks
I got the dreaded F22 code on my Whirlpool washer. The door does open and closes. I pushed the sensor pin, after about 40 seconds, the code pops up and the washer shuts down. First, i disconnected the washer and after 20 mins, turn it back on and same thing happened. I waited 24 hrs to turn it back on without any luck. I order the latch mechanism (AP3968085) from here and replaced it without luck. I also bought the strike (AP4366423) but never used it because i did the push pin test on the latch. What else can be the problem? I hate to replace the Control
