can't fix F2 code
My sister has a Whirlpool clothes washer identical to mine, only 1 year older. The F2 code came up. I have checked the pump. Spotlessly clean. Checked the pressure sensor tube. Clean and clear. Tried replacing the pressure sensor. Still the same problem. The pump is pumping lots of water on "spin & drain". Tried unplugging washer to clear the computer. Doesn’t help. After all this, the washer cycles are not right. Any suggestions on what to try? Do I need a new control panel or different microprocessor?
