My wife was doing the laundry this morning and came downstairs and heard a buzzing noise. It was coming from are washer and it was displaying the fault F2 and it’s not spinning anymore. Any thought?
mrbruce
mrbruce
Hi Mr. Bruce
You get this code because the machine thinks it is taking too long to drain all the water our before the spin cycle can begin, and so it shuts down the machine because the water is not out, or so it thinks.
The initial response to this is to take off the bottom panel and take off the hoses from the pump and clean out everything (note: water will come out so be prepared)
Make sure there is nothing in the pump or the drain hoses, and try again. If that does not work post what you did and the results and we will see what else we can do.
Good luck.
