whirlpool duet washer tub problem
I have a whirlpool duet front load washer ghw9150pwo. After running a load of wash, I found pieces of plastic on the clothes. Upon further inspection, I found strings and chunks of plastic by the drain inside the bellows. The plastic tub around the inner basket has rough edges and seems to be missing pieces. The basket still spins but is free to move from side to side due to the enlarged opening. Which parts would I need to replace? Should the be covered by warranty? Does the unit have to be inspected by a technician before parts can be ordered? thanks
Hi Wayne
Sounds like the rear tub bearing has a lot of play in it.
So, besides the front and back tub, any parts I might need?
