Whirlpool Duet washer
The tub on my Whirlpool Duet front-load washer wobbles and rubs when it rotates. Under the gray tub seal are plastic shreds and chips. What is disintegrating here and is this something I can repair myself? I’m fairly handy and crazy enough to try it. Any one else experience this problem?:confused:
Is the inner basket rubbing the outter tub? If so and you have chips from the front outter tub, you will need both of these parts to do a proper repair on this unit. Also you need to check the spinner shaft on your inner basket to make sure it didn’t get damaged. If so you will need a new basket as well.
[part]AP4426951[/part]
[part]AP3773838[/part]
Basket Assembly
[part]AP4459040[/part]
Tub and basket replacement parts for WHIRLPOOL GHW9100LW0 | AppliancePartsPros.com
