Whirlpool duet won"t start
My whirlpool duet washer will not start. The lights are on, and the red light showing the wash selection is flashing. But the cycle will not start when the start button is pressed. Does anyone have a repair manual specifically for this model? Is this worth trying to repair?
— Begin quote from happymom;343835
Happymom,
You should start by checking the door switch/ door latch circuits and operation,
You also need to make sure the door is Openned and Closed, between cycles.
As you requested, here’s a service manual attached,
You’ll have all the information you need.
[ATTACH]2620[/ATTACH]
Do you hear the click, or just hold the button and no click?
I posted regarding a similar problem, but never got a response.
Have you tried a different selection for the wash cycle? Sometimes I have to change selections between loads to get a second load to start.
And, I almost always have to hold the button down for at least 30 seconds to get the click and have the cycle start. Sometimes I can hold the button down and it will never click.
None of my cycle modification buttons work anymore. I used to be able to get some of them to work, but now none of them do no matter how long I hold them down.
Thanks to the person who posted the service manual!
Signe
Many thanks to Joe/APP team for posting the manual. Using it I was able to open the Front panel and manually start the unit. I was able to run the diagnostic mode and found problem with drain unit. A paper (bounce) was stuck after the large object drain filter in the drain pump and it won’t drain the unit.
The start button gets pressed by a small plastic strip which is broken. Need to find the replacement part.
— Begin quote from tjsingh;438944
TJ,
We’re Glad things went well for you, and your up and running,sort of.
If I remeber correctly, the start button plastic tab, you described, is part of the "user interface" assembly, but I’m sure you’ll be able to do some sort of repair to make it work.
Good Luck, and Thanks,
:smiley: :smiley: :smiley:
Many thanks AGAIN to Joe/APP team for posting the manual. Using it I was able to diagnose a similar problem with our Whirlpool Duet and th door locking mechanism. Thank you. :slight_smile:
Read more: http://forum.appliancepartspros.com/washer-repair/167843-whirlpool-duet-won-t-start.html#ixzz27rtgUnde
— Begin quote from Gcope;772647
Gcope,
Glad we could help you out.
We’re here to help, drop us a line anytime.
Thanks,
My washer won’t run the test it just flashes the 2 min time. Any thoughts? Thank you
— Begin quote from adidaalaska2001;818834
Adidaalaska, Start at the User Interface. If the washer won’t accept programming inputs or operate, that’s where you will need to start.
You forgot to attach a model number, some washers have a U/I test matrix so you can test the buttons with a meter. You may need to review the tech data sheet, to see if yours has the information.
I’m having a problem with my ghw9100lw where the timer changes when selecting different cycles, buttons all work but won’t start. I tried billions of times to due the diagnostics test but the time just flickers when pressing the rinse hold button for the fourth time. On top of that when I’m in this cycle setting ready for diagnostics if I press start I hear a click in the back and the number flashes. I’m truly at a lost because I can’t find anything online dealing with the machine showing no error codes or not going into diagnostic mode.
Tdouble14 said:
I’m having a problem with my ghw9100lw where the timer changes when selecting different cycles, buttons all work but won’t start. I tried billions of times to due the diagnostics test but the time just flickers when pressing the rinse hold button for the fourth time. On top of that when I’m in this cycle setting ready for diagnostics if I press start I hear a click in the back and the number flashes. I’m truly at a lost because I can’t find anything online dealing with the machine showing no error codes or not going into diagnostic mode…
Tdouble, Remove the top panel, and unplug the power cord from the outlet, locate the CCU, it’s attached to the side or back wall of the cabinet. Listen closely, when you plug the cord back into the outlet, you should hear a click from the line relay on the control board. If the click occurs, use the attached tech sheet to access and check the user interface and control panel keys, and the harness between the UIC and The CCU. Review the troubleshooting information at the end of the manual, it’ll help you to find a place to start the diagnosis process.
If your duet washer won’t start its most likely due to a bad part behind the start button.
Here’s how to fix it at home for 35 cents: https://youtu.be/N8rz8sclwAg
Scott, Thanks for the update and the You Tube Repair Video. We appreciate it.
— Begin quote from Joe / APP Team;903988
Are you in charge here?
Just in case you didn’t notice, Scott is a SPAMBOT. "he" posted that same post in 7 other places on this forum and twice in this thread.
The youtube address he links to is youtu.be. Yeah, that just ain’t right!
Notice the link below. youtube. Its a real one, his is not.
https://www.youtube.com/watch?v=Q3eYF53Pj8g
That Guy, No I’m not in charge, I’ve been here a while, bit I don’t post or reply to the repair forum as often as I used to.
I don’t know of Scotthefixitguy, and yes he has posted the you tube video several times, but it was a quick simple temporary repair and easy for most DIY’rs to view and repair the machine. I’m sure there are other methods and components to use for a more permanent repair, but thought it would be helpful, down the line. Thanks for the update and heads up.
:slight_smile:
Here is a video on how to repair the broken start button using duct tape.
It saves you about $300.00 on a new interface control board.
Hope this helps: https://youtu.be/N8rz8sclwAg
Good Luck,
Scott
Happy mom how did you get your machine working? I’m ready to blow this one up!!! It’s doing as you posted. Thx Brandon
BRT123, Happy Mom didn’t post a response or an update. But , Like her and most of the people on this thread, you most likely have a problem with the user interface tabs, so you’ll need to remove power and access the user interface and check for broken buttons and tabs. All the information you need is posted through out the thread(including the service manual) Once you’re there and determine the problem isn’t the User Interface, drop us a line, and let us know what you did find, and we’ll carry on from there. Thanks,
