Hello, I’m new to the website and found it through some searches on this E1-F1 error code I’m getting on my range. There was a power outage recently and I noticed the error code after that. The top range heating still works, the oven/timer/broiler can’t be operated because the control keeps showing the E1-F1 error code.
I found your error code specific page for whirlpool ranges and it says the approach should be to replace the control board. I’ve already done the procedure of unplugging the unit, waiting, plugging it back in and waiting some more. Unfortunately, the error code still remains.
Whirlpool is out of stock of this electronic control board:
http://www.whirlpoolpartsonline.com/ez352-pyro-elec-control.html
I found the electronic control part here on AppliancePartsPros’ website:
http://www.appliancepartspros.com/whirlpool-control-range-9753633-ap3008287.html
Is that the correct part that I should replace according to the error code? It looks right because the cross reference part number matches the number on my Whirlpool manual and it matches the diagram.
Any tricks to replacing this or things I should watch out for? Thanks for the help!
Whirlpool Gold Accubake System
Model #: GY396LXGQ5
Serial #: IML3496088
