side by side, frig and freezer not cooling, opened the back, fan is not working, don’t hear anything else on (like the compressor), the lights work though, and i vacumed all the dust out, what could be the problem?
Are you sure it is not a ED22TWXDW02?
I could not find any info on the given model number but did find the above.
Here are the parts for the unit I could find.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=248585
Sounds like you may be stuck in a defrost cycle.
The compressor, the condenser/compressor fan and the evaporator fan all will be off.
Try forcing it out of defrost by turning the defrost timer (Item 6 in Section 11) cam with a screw driver. It only can be turned one direction also there is usually a hole in the control cover to let you do this.
If the unit fires up you need a new timer.
