i need to change belt on this whirlpool front loader mdl: wfw9150ww01.
i know I have to take rear cover off unit but what else will I have to conquor to change this belt out. any help would be appreciated
— Begin quote from sskeetr1;444079
Sskeetr,
After you remove the rear panel, you’ll have access to everything you need.
Remember, the belt will look too small, and can be very hard to install, the easiest way, place the belt on the motor pulley first, and "roll" the belt onto the drum pulley, by placing the belt on the bottom and slowly turning the pulley until it is on, turn it a few more revolutions, to make sure it is aligned on the pulley(s) then put the washer in a spin cycle for a few minutes.
Good Luck,
