Whirlpool Gas Dryer LGR4634JQ2 - Thermal Fuse
Hello. I’m experiencing no heat on this model gas dryer. I tested the continuity of the thermal fuse and its open, so I’m going to replace it. My question is, if I replace the thermal fuse, should I replace the thermostat at the same time. I read somewhere that its recommended to replace that too at the same time. If so, which thermostat should I replace (I see there are 2 different ones in this model)?
Thanks so much for the help!!!
