Whirlpool Gas Dryer Repair - Need Help Please
The dryer runs and heats up for about 10-15 minutes and then the heat stops after. The dryer continues to run without heat. What part needs to be replaced with this kind of issue, thermostat? How do you change/install that part? Any instruction you can provide would be greatly appreciated.
Also, the other issue I’ve noticed is when I turned the knob to the setting "very dry", it doesn’t move to "off". We were told it might be the timer we need to change. Is timer / thermostat the same thing for this model?
Please help!
Thanks,
Cris (desperate mom with piles of laundry to wash and dry) :confused:
