Whirlpool gas dryer won't start. Fuse is good
My Whirlpool gas dryer won’t start. I have power to the unit. The timer runs, no tumbling, no heat when I press the start button. I can hear the relay click when I press the button after turning the dial to off, then to a setting. Tried all settings. Nothing works. There is continuity across the the thermal fuse.
Any help would be appreciated.
I saw a post with a similar problem, but on a Whirlpool electric dryer. That individual finally determined that the issue was the timer motor. How would one go about testing that device?
Hi.
Using the multimeter check the continuity:
  • door switch Blue to White closed.
  • start switch Black to Blue closed (with power on and switch pushed in).
  • timer on timed regular TM-OR, BK-BU, T-W all closed.
If all of the above checks OK - replace the motor.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139048
Thank you. Post the results.
Simon.
    Disconnected door switch and tested outer leads with door closed, then open: OK
    Disconnected wires from timer motor and tested Black to Blue: OK
    [COLOR=Purple]With dryer unplugged, set timer to "timed drying" and tested prongs of timer motor.
    TM-OR: OK
    BK-BU: OK
    T-W: [B]NO continuity
    [/B]Does this indicate a different problem?
Thanks in advance for all of the assistance[/COLOR]
Hi.
Install the jumper on T-W and start the dryer. If it kicks on - replace the timer.
Simon.
That was it!
Thanks so much for the assistance. You’re an asset to the forum.
Parts will be on order tonight.
My pleasure.
Simon.
— Begin quote from Simon / APP Team;755898
Hi.
Simon.
Can you run the dryer with the jumper on T-W, without replacing the timer?
Greg
Hi.
Why wouldn’t the manufacturer make the timer with contacts T-W closed all the time?
If the timer is shut, replace it.
Simon.
