Whirlpool Gas Oven doesn't get hot enough
This Whirlpool gas oven doesn’t ever get up to temperature. To get to 300 degrees, it has to be set to 400 and wait half an hour. This oven has never worked right. The stove works just fine though, but it would be nice to use the oven. This oven came with the manufactured house and unfortunately, the warranty card was not sent in early enough to make a difference. Here is the serial number in case it helps: ver2806190
Thank you for your help! I think I know what might help, but you are the Pros!
