Whirlpool Gas Oven will not heat up to desired temperature.
Hello,
I have a original builder model Whirlpool Oven that no longer reaches desired temperature. It takes an hour to reach 400 degrees and 45 minutes to reach 350. I already replaced the oven temperature sensor and it did not help.
Any other suggestions?
Captjob
Igniter is week and can’t always light the oven when it calls for heat.
OK thanks. I’ll order another igniter.
Captjob
You already replaced the igniter once before?
To test the igniter I would use a clamp on amp meter and see if it’s in range with what is marked on the side of the gas valve.
