Our top oven was in self cleaning mode when we had a power outage. After the power came back on, the control panel was unlit. We have checked the breaker and it is working fine. Also tested the "oven thermal shutdown fuse" on the back and it is OK.
Check the low voltage transformer behind the control panel (5 on the [AP3968801](http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=118533&&model_id=264603"]break down diagram[/URL]).
- The part number for the transformer is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3968801&&model_id=264603&diagram_id=118533)
Here are the break down diagrams for the Whirlpool oven http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=118530&&model_id=264603
— Begin quote from bnygaard;42636
…ticket says "Sub CNTRL-EL"…
Look for the part number on this ticket and post it here.
