Whirlpool GEW9250PW0 duet dryer. Right around the 10 year old point.
Was shutting down due to vent being clogged. Had vent pro cleaned and seemed good to go again.
About two months after the vent was cleaned out, it has started shutting down again mid-cycle. The panel is still on, and the time counts down. It will start up again after an indeterminate amount of time. The room is inside the house, and not overly warm.
After it has shut down and the time left expires, if I set a cycle and press the start button it looks normal on the panel, but clicks and does not start until (I’m guessing) that it cools off enough to start again.
