replacing the seal kit on the impeller. Part #23 is a washer with rubber on one side and the metal on the other. Which side goes toward the impeller and also which type of grease and amount?
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?&model_id=5138898&diagram_id=954610
