Whirlpool In Door Ice Maker Not Making Ice
The ice maker stopped making ice. I have done some testing thus far.
[LIST=1]
*]No water into the ice tray.
*]Nothing stuck anywhere.
*]Swapped leads on the water valves (door water/ice water). When the door water was pressed the ice maker tray filled with water.
[/LIST]
I tried testing the wire couplers that connect to the water solenoid for power but found nothing on either. I am not sure what the next step would be. Should the door/ice water solenoid valve be replaced or is there just no power getting the ice maker side of the water solenoid? :confused: I have read through some of the other threads but they all found something stuck and did not get to the point that I did.
