I have a Whirlpool Inglis dryer that suddenly wont heat up. Also the timer is not working allowing the dryer to keep running unless the knob is manually turned to the off position. Both problems happened at the same time. I know the problem is not the breaker/voltage because I just had that checked. Also, we ordered and installed a new heating element and this did not solve the problem. Could this be a thermostat problem? Or perhaps a timer issue?
Timer doesn’t advance in both auto-dry and timed dry? Sounds like a bad motor switch. With dryer running in timed dry, check voltage between timer terminal F and power cord L-2 connection at connection block. If you read 240vac, then the motor switch is bad. If you have no experience at this or are uncomfortable doing it, then don’t, line voltage can be lethal.
Eric
Thanks for the reply. I need to buy one of those voltage indicators. Would come in really handy with this dyer. Wouldn’t a bad motor switch cause the dryer not to tumble though? Forgive me, I don’t have too much experience fixing them. Any other suggestions?
There are two sets of contacts in the motor switch. One is for completing the heat circuit.
Eric
See the attachment for your wiring diagram.
As fairbank56 said it is important to check if the timer does not advance in both timed dry and auto modes.
As you can see from the wiring diagram the timer motor gets power through different paths depending on cycle type.
Note that both the timer and the heater run off of 240 volts.
If both modes do not advance it could be a bad heater centrifugal switch on the motor, no 240 volts or a disconnected/bad connection wire either in the wires in the unit or the line cord.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
I have the exact same problem(s)! No heat, and the timer wont switch to off except manually (haven
t checked whether it is both timed and auto).
I had been fooling around with testing thermostats, coils etc. in the hopes I could fix this myself. All with appliance unplugged of course. There is no way I am messing around with 240v as described above, though.
Damn… may have to pay someone to fix it… or is it cheaper to just buy another used dryer…
