Whirlpool Oven - lower heating element not working after self cleaning
Hi there (Gene?)
We used the self cleaning feature of our oven for the first time ever. Had a little trouble with the locking lever and its possible that the internal mechanism which allows heating was damaged. (I can post an image if that helps)
In any event, the lower coil does not heat up any longer. Top works fine. All physical connections are intact and connected.
Can you please offer your expertise on how I can repair?
Many thanks,
Paul
Hi Paul,
You may want to start the troubleshooting from checking that heating element for continuity.
The model number you posted is incorrect. Please verify and repost it.
Thank you Gene, for your response.
The correct model number is RB260PXBQ2. Sorry for the earlier mistype.
Additionally, I am posting a picture of the oven lock assembly. I have a feeling something is broken/missing. Perhaps a spring?
Thank you again for your help.
Paul
Hi Paul,
I do not think the latch has something to do with the Bake element not heating.
If the heating element itself is good and there is nothing wrong with the wires then the problem is a bad control board. Unfortunately this part has been discontinued by the manufacturer.
  • The oven Bake element [part]308180[/part]
Here are the breakdown diagrams and Parts for Whirlpool RB260PXBQ2 Wall Oven - AppliancePartsPros.com
