I have a Whirlpool gas ovev (mod# SF362LXSQ) that is just under 2 years old that the oven and broiler have stopped working. The stove burners work fine.
When you try and start the oven, you hear several "clicks" and then nothing. When it did work it would "click" then you would hear a rush a gas and the oven would heat up.
All power and controls on the panel seem to be working fine.
When we first moved into our house 5 years ago it came with a Kenmore oven that was 3 years old and eventally started doing the same thing. A repair man said something about a control panel being the problem and it was more economical to replace the oven then just repair the old one. Now we seem to be having the same problem with the new one.
Has any one heard of this being a common problem and what are some ideas to try and fix it.
After looking around on the web a lot of people seem to think this could be the ignitor. I have removed the ignitor, but is there any way to test it and see if that is the problem?
If your oven has a bake and a broil burner it’s not very common for both ignitors to fail at the same time I would lean more to trouble shooting the board
I am experiencing the same problem, but both legs are measuring approximately 208 ohms. Is this close enough, or is there some other problem? No gas at all is making it out of the valve when I disconnect the lines. Im at a total loss here.
The problem is that the oven/broiler does not heat up at all. I checked the gas flow at the valve for the cook top burners, and all is fine there, but nothing comes out when I try to start the oven part. I checked the resistances, but all looks normal there too.
[SIZE=1][FONT=Swiss721BT-Roman][SIZE=1][LEFT]Check between each solenoid for 216 [/SIZE][/SIZE][/FONT][SIZE=1][FONT=SymbolProportionalBT-Regular][SIZE=1]Ω [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]resistance
(Broil terminal to Common, and Bake terminal
to Common).[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Bold][SIZE=1][LEFT]NOTE: [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Always check both solenoids. If one of[/LEFT]
the solenoids is defective, neither one will operate
Remove the bottom drawer. Locate the gas valve/regulator with three electrical solenoids terminals on the back of the range. The middle terminal is Common, the upper terminal is Broil and the bottom terminal is Bake. Mark all wires and remove them from the terminals. Check between each solenoid for 216 Ohms resistance (Broil to Common and Bake to Common). If one of the solenoid is defective, neither one will operate and the gas valve/regulator has to be replaced.
The part number for the gas valve/regulator is AP3866825
If there is nothing wrong, post the results and we’ll proceed with further diagnosis.
I found this post after having the same problem with my oven. The repair man that came to fix it could not figure out the problem until I showed him this post. He tested the solenoid as you instructed. To make a long story short, we replaced the gas valve/regulator and our oven is working great!!! Thank you much!!
Gene… We have a similar problem, igniters spark as req’d but oven and broiler burners do not light The resistance across the oven and broiler to common on the control valve each measure about 196 ohms. This is with a cheap tester… whereas it should be 216 ohms… would there be this much error from the cheap tester? Or is does the control valve need to be replaced?
Can you smell or hear the gas open while it’s sparking?
just outta curiousity, should i be able to see the ON on the safety valve when it is in the proper position so that the oven will work? i am trying to diagnose the same problem these ppl had (no oven or broiler, but stovetop ok). thanks.
harry
