My Whirlpool Stove top and Oven will not heat up. I was using two burners on the stove top to boil water and cook meat when both stopped heating up completely. I checked the other two burners and found that they were no longer working either. I then attempted to heat up the oven and found that it would not heat either. The digital displays and lights continue to work however the stove top and oven will not heat up at all.
Any suggestions on what could be wrong would be greatly appreciated.
Thank You!
