Set the oven for 350 and it only reaches 200. Display actually shows 350 but a thermometer inside the oven shows only 200 degrees. I can feel heat from the broil element but the bake element is covered, not sure if it glows.
In diagnostics mode I get:
71 degrees
U-00 user offset
S105 software version
31Fb memory checksum
Good board check
782 hours run time
01 door closed
When I break out the trusty multimeter and consult the tech sheet I get:
oven temp sensor - meter says 1096 ohms, sheet says 1000-1200 at room temp
Thermo fuse - meter says 39 ohms, sheet says it should be 0 ohms
Bake element - meter says 22 ohms, sheet says 10-40 ohms
Broil element - meter says 16 ohms, sheet says 10-40 ohms
I have no clue what’s wrong. I’ve replaced the cord(used the old one when we bought this one, worth a shot), replaced the oven sensor(anybody want to buy one, only used once?), I’ve swore at it, gone to church over it…the only reason I haven’t picked it up and thrown it out the window is because with my luck I’d get a hernia…help please…
