Whirlpool RBD276PDQ11 Display and Oven Not working
I woke up this 2 days ago and my oven display is not working. When I press a button, the oven beeps, when I try turning on the oven, I get 2 beeps, then 3 beeps. A day later, the display was working an said E6 E2. I guess I need to know what to test to see what needs to be replaced. I see the control board is discontinued but can be sent in for repair. Any advise would be awesome.
Anyone? There must still be a pro on here somewhere?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RBD276PDQ11
Not sure about the error codes you give are you sure it was not F2 E6, see the tech sheet.
Looks like a keyboard problem.
There is not a good way to check thee keypad as they do not publish key/pin-out info.
I would try the following and if that does not work then replace the control panel/keypad. This is a gamble but you do not have another option.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
