The interior lights still work and we get a few beep sounds but the oven won’t heat and the front panel (clock, etc.) is out. Wondering if its a control board issue. Anyone know how to replace one?
Thanks.
~Bill
Thanks.
~Bill
Hi Bill,
Check for continuity the thermal fuse wired into the hot line ti the control board. If the fuse is fine then the control board itself is bad. Unfortunately this part is no longer available.
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-whirlpool-rbd305pdq11.html
