Whirlpool Side by Side Door Handle
Door handle on refrig side is loose. How can I tighten it or replace it if required?
Here is your parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GS5SHAXNB00
Looks like you pull upward on the handle and it should release from the retaining clips
Thanks for the info but I tried to push upward but NO GO. Again thanks!
