Whirlpool Top Loader
Recently my Washer wasn’t spinning at all , but it did everything else. Of course the clothes didn’t drain ALL the water out because of the spinning problem.
Now, yesterday I replaced the coupler, and it will spin …SOMETIMES ( sometimes it seems like its stuck, so it’ll move just twice then stop), but it won’t do anything else… The water will fill up, but after that sometimes it makes an extremely loud noise while spinning, sometimes it just won’t do anything at all (but it sounds like the motor is running), and now most of the water won’t drain out (some water will come out, but after that little bit, then the machine will suddenly stop).
It seems like it has more problems now.
Could it be that i did something wrong when I replaced the parts, maybe a wire in the wrong place, or something???
I would check the pump for a foreign objects inside.
