whirlpool toplaod
I am having an unbalanced condition with my Whirlpool washer, topload. I checked the loads to see if there balanced, there O.K. I also checked to see if washer is level, it is level. I am thinking it might be internal. Anyone know where to look and what part might be causing this.
Check to see if there is a broken counter-balance spring in the back of the machine, underneath it. A telltale sign is if the tub is tilted forward (you can see this when you open the lid).
AP4459650
I’ll give er a try!
