after loading washer & turning on it started to put water in & after about 30sec. it stopped & began flashing HF code. Is this worth calling a repairman or is it something we can troubleshoot. Or do I just need a new washer? Please help
Hi,
Are you sure the code is HF?
There is no HF code listed in the service manual.
There is a F/H error code.
[QUOTE]No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.[/QUOTE]
I believe the model number should also be 9100 and not 1900 as you posted it.
