I’M NOT SURE OF THE AGE OF THE MACHINE. IT KNOCKS IN EVERY SPIN CYCLE. I’VE REPLACED THE 3 BIG SPRINGS,BUT NOT THE ONE LONG ONE YOU CALL THE SUSPENSION SPRING. I JUST MOVED THE BOTTOM OF THAT SPRING TO A HOLE IN THE FRAME TO SEE IF THAT HELPS. SHOULD THE SKATE PLATE BE SECURED WITH SCREWS BECAUSE I DON’T SEE ANY SCREWS IT IT? IT DON’T MATTER HOW MANY CLOTHES ARE IN THE MACHINE, IT SOUNDS LIKE A VERY HEAVY UNBALANCED LOAD IS IT IT. HELP !!! :eek:
No, but I would have replaced the skate plate along with the three springs.
