Our washer has gradually stopped spinning. It is about a year and two months old. It started to not spin about 50% of the time, and now, after about 2 months, it is very rare that it spins at all. Our clothes always come out soaked and unable to dry.
Any help would be greatly appreciated on how to fix this.
I hear a humming sound when it is supposed to spin instead of the normal spinning sound. It does drain I believe, but my clothes do come out a bit soapy sometimes. I don’t know if the motor runs or not, but the humming may indicate something.
Thank you for the help. I did test the voltage between T & H and got nothing, any ideas. I did do a jumper from M & N and the gear & arm turned. I also installed a new circuit board and heater core. I also tested the valve by jumping the ends directly to the 120v plug and water did run into the icemaker.
