whirlpool washer
Washing machine is getting plenty of water yet still get FH error code and washer stops.
A lot of times this is a bad flow meter.
The tech sheet is under the top cover on the right. Check the connections, and if nothing comes up wrong I would replace the flow meter and see if that doesn’t solve the problem.
