whirlpool duet
Washer stops approx. 1-2 minutes into cycle with f/h error code. Cleaned filter, checked fill hoses for kinks etc. Ran diagnostic test. Failed c:01 with f/h code. Skipped to c:03 and machine fills and drains without failure. Skipped to c:06 and machine drained ok. Is this an indication of a bad flowmeter? If so, where is it located?
yes it is more than likely the flowmeter… remove 3 screws from rear of top panel slide top back and off machine you should see the flowmeter on the left hand side… white round part with black hose on each end. if you replace it be CAREFUL taking off hoses or you will break the plastic on the dispenser end of hose ,good luck hope this helps
Thanks, I’ll give it a try
