it seems to be be working until the spin cycle -its just isn’t completely getting all the water out of the clothes and when it stops you can hear water in the bottom of washer but you can’t see any so I have to put it on the spin cycle two to three times to get all the water out of the clothesand when it spins and drains it seems normal :mad:
Sounds like the clutch could be slipping. Reminds me of this service call I did awhile back. It’s a different model number, but it had the same problem and uses the same clutch as your model.
http://appliancejunk.com/forums/index.php?topic=9087.0
