whirlpool will not spin/agitate
hey all i have a whirlpool washer model lst7233aw0 and it fills and drains but will not spin or agitate. when its in the agitate mode i can see the agitator wiggle a little but otherwise nothing. then during the spin cycle i get a high speed humming sound like the motor is spinning but the drum will not turn.
and thoughts? coupler? transmission?
dont want to spend alot on a service call if i can avoid it.
thanks
This looks and sounds very much like the coupling. Not a difficult repair, takes a little time and it helps to have someone with you.
Here is a good video that will take you through the process of checking it out.
http://www.youtube.com/watch?v=WLPGs2UMUJc
