Hello,
I appreciate any help. My Whirlpool washer LSQ8243HQ0 will not agitate, spin, or drain. But, it will let water in. Please help!
Hello,
Hello.
Before we go to any trouble is the motor running?
Open the control panel, go to the water level switch. With tub full of water (Washer unplugged) check the continuity (using the multimeter) between V and T. They should be closed. Install the jumper wire from T to V. Turn the washer on. If it starts - replace the water level switch.
If not go to the lid switch disconnect plug (3 wire plug on the top). Install jumper between two outside wires.
Plug in and start the washer. If it works - replace the lid switch.
The water level switch [part]AP4567832 [/part]
The lid switch [part]AP3100003 [/part]
Here are the breakdown diagrams and Replacement parts for Whirlpool LSQ8243HQ0 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
