Whirlpoor Holding Water after complete
My dishwasher is holding water in the bottom after a cycle is complete. I have to push the drain/cancel button 2-3 times for it to completely empty. I have checked the drain hose and it is clear. I do not have have a garbage disposal. I took off the front panel and removed the hose that is connected to the check valve. The check valve looks clear and when I click on the cancel/drain button the impeller spins freely.
Any advice or suggestions are appreciated.
