I suppose we should be greatfull that we’ve gotten 5.5 years out of this before this issue. Symptoms:
Failed running a load.
Unpluged and replugged in all connections at the CCU; MCU and Motor.
Ran an empty Drain/Spin cycle and cycle completed. Re-ran a normal Whites Load got to Spin cycle with no errors. Washer went into Spin cycle and heard Drain pump running, drum not spinning after a bit time left on the cycle started flashing, heard pump cycle again and drum didn’t spin time left lite solid for a a few seconds and started flashing again, pump ceased, cycled like that again and got F06 error code.
I’m thinking MCU or Motor or both; wish I could aford to just replace both, but would love a more definitive suggestion on what part to buy.
Any suggestions; since the unit made it past the rinse/spin cycle with extra rinse setting all the way to spin but never started to spin the drum kind of sounds like it’s heat related failure on some component.
Many thanks - you all provide a valuable service to people needing help from reading the forums trying to get answers here.
