Whirpool Duet Washer wont start
I have a Whirkpool Duet Washer and it will not start once i press the start button. There is no error code either. Could it be that the motor control unit is gone out or the motor. The unit has power all lights are on it just won’t start.
I replaced the [AP3837611](http://forum.appliancepartspros.com/Appliance-Parts/whirlpool-door-switch-assembly-item-number-ap3837611.aspx"]Door switch assembly[/URL] - Used on front load washers. Door latch lock includes interlock switch assembly.
Part Number: [URL="http://forum.appliancepartspros.com/Appliance-Parts/whirlpool-door-switch-assembly-item-number-ap3837611.aspx) made by WHIRLPOOL
replace the MCU… i just did and it works.
