Whirpool washer does not stop automatically filling up water.
I just replaced the new inlet water valve. When the machine start filling up water and could not stop automatically. At one point when the machine on rinse circle did not filling up water and when it finish the circle, the water start filling up again. Can anyone help me out?
If water is running when the machine is off the problem is with the valve assembly.
If it will not stop when it is filling, but will stop when you shut the machine off, check the hose from the tub to the water level pressure switch. Make sure it is on tight, that water does not enter it during the fill and that it is clear at the tub level and there are no air leaks.
If all that checks out, try replacing the water level switch.
