The washer will stop filling before it reaches set water level. If you turn washer off and restart it will fill some more and stop filling again. Water lines are not obstructed. Any Suggestions.
Take off the cabinet and clean out the tube from the water level pressure switch to the tub. This site will show you how to remove the cabinet.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
If that does not fix it you may want to replace the water level switch itself, but see if clearing out the tube will work.
