whirpool washer
Machine Wont Spin , Drain , Or Agitate. Motor Is On And Noise Is Coming From Near The Motor But Nothing Works. Have I Blown The Transmission Or The Coupler Or What? Thanks For Your Help.
— Begin quote from sidfink43;85897
Check your motor coupling, as this video will show. Note, you do not need to remove the pump, just tie it off to the left.
YouTube - Direct Drive Washing Machine Repair Video Tutorial Watch in HIGH Quality!
Let us know what you find. If it is not the motor coupling run the machine with the cabinet off and see if you can locate what noise you have.
Good luck
reply-- thanks sidfink43 thats exactly what is was, vecaz
