[SIZE=3]I have a Maytag MAV2757AWW washing machine. It’s about 5 years old. Last night it tripped the circuit breaker when the spin cycle started. I played around with it some form and found that it would run the agitate cycle without a problem. Every time it reaches the spin cycle it trips the breaker. [/SIZE]
[SIZE=3]Things I’ve check. I have manually spinning the belt on the bottom to see if it was jammed. No problems spinning it either way. Let me know if my thought process is wrong but I think that that eliminates a stuck transmission or bearing. Because the motor runs during the agitation cycle I feel like that’s not the problem. The only difference according to the schematic between spin and agitate cycle is the polarity of the current. The only thing left that I can think of is that the problem is in the Timer module. [/SIZE]
[SIZE=3]Any other ideas?[/SIZE]
[SIZE=3]Also when checking the Lid switch I found that it passed current in the open and close positions. I think I have a bad lid switch as will but I don’t think this is causing the problem because as far as the washing machine is concerned it thinks its lid is closed. [/SIZE]
You have to run a few tests and post the results. You have to measure the current drawn by the motor, and separate by the whole washer, during the spin cycle.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174151
