Will not agitate or spin
Hello!
I have a washer that will not agitate or spin. The washer will fill, begin its agitation…will agitate maybe once or twice…then stop and the "wash" light will blink. When set to spin, the washer will drain, then begin its spin…after about a second…it will stop and the "spin" light will blink.
I have put the washer in service mode and tested the cycles. It will spin and continue to spin when I am testing it in this mode, however, it will not agitate while testing that.
I have replaced the lid switch, the lid lock, the control board, and gave it a whole other bucket (including its motor/transmission/agitator) from a different washer that worked. But when I went to run the wash, the same thing would happen…stops at agitation and "Wash" blinks.
Thank you for your time.
