washer repair
Washer won"t agitate or spin. I have checked the lid switch. What should I check next?
Operate it with the front panel off and see if the motor is turning or trying to turn when it is in agitation or spin cycle. If the motor is not turning and will not operate you have a problem with the motor or the control unit or the wiring.
If the motor is turning but nothing is happening then the transmission is likely the problem, but check the clutch also.
