Found that the washer had been loaded way too tight this morning by the kids. I caught it very early on, but there was an electronics burning smell in the laundry room. So, after I pulled over half the clothes out, I thought we were ok. The wasther agitated fine. However, it would not spin. It clicks like it is going to spin cycle and drains as it should, but no movement. I removed the front and top panels to visually inspect. All looks good. The Magnetic Lid switch gets continuity when closed as it should. I ran it through a cycle with the front off so I could watch. Agitaties fine, but when it comes time to spin, there is no movement from the motor at all. What should I look at? Should I pull off the belts and look at the motor transmission, or should I suspect the timer/ electonics up in the control area? Any help would be appreciated. I can post pics or vids if you need them to diagnose…
When I put my hand under the motor pulley and spin the motor pulley and transmission 1 way (the belt is still on it), it spins freely. When I spin it the other way, it does spin the bucket. Is this how it agitates and then spins? It turns the motor 1 way to agitate and the other to spin?
— Begin quote from mhamlin2;323220
I have the washer on it’s back with the belt off. I did it just like this video suggests: http://washer-dryer-repair-videos.com/GE-washer-video-clips/do-not-spin/GE-HP-washer-transmission-sprin.wmv
When I turn the dryer to any cycle position, it does not turn the motor. Is this because of some sensor now that I don’t actually have water in it or it is on it’s side? I have a magnet on the door switch and I hear it clicking so I think that that switch is closing properly. The only thing I can get to work, however is the pump. Any help would be appreciated. Between work and a houshold of 5, we can’t do without this thing for long.
Ok. I walked away for a while and came back. I found out that the magnet I was using wasn’t triggering the lid switch well enough even though it made the sound. So, what I have now:
The motor spins when it should be on a spin cycle. However, I cannot get the motor to spin when it should be agitating. Is this because the water level sensor does not trigger since there isn’t any water? This is exactly opposite of what is happening when the Washer was all together. It was agitating, but not spinning.:eek: I am hoping it is a sensor or something not allowing it to spin in the agitate direction. If that is the case, it looks like my problem may be somewhere in the transmission/clutch/agitator area?
