Works great until drain cycle…timer does not advance and machine is completely silent. Lid switch appears to be good when ohmed and when performing a by-pass test, washer still fails to enter drain cycle. Any suggestions? Also, when checking the lid switch…what is a normal ohm reading? Again, washer is a kenmore/whirlpool 80 series model number 110.28812790. Thank you, pj3
can someone help me i have a whirpool gold and after the washing cycle is over it does not drain or spin cycle it just stops.is there a part that has to be changed and what part do i need so i could do it myself.please i need an answer a.s.a.p water is still in the tub since last night
thks
I would temporarily bypass the lid switch with a wire and see if it works.
