Washer will not spin fast enough to wring out the water. Is the Transmission suppose to spin during the spin cycle, cause it doesn’t. I replaced the pump and belt a couple of months ago and don’t believe this caused this problem but didn’t want to leave this info out.
I recommend you to follow the below stated routines
Test the lid switch
Test the timer control
Test the centrifugal switch
Test the water level switch
Inspect the motor coupler
Inspect the drive belt (belt drive only)
Inspect under the washer for soot (clutch)
Test the motor
Inspect the pulley
Test the transmission
And as for the clothes being wet after the spin…This may be a spin problem or a drain problem
:::::SEMO:::::
